analytical mechanics off coiled-tubing
I have looked high and low for journal papers etc. with little luck.
In order to design a coiled-tubing reel one needs to calculate the applied loads.  For a given tube size/material, tube tension, number of layers, and core radius, how may the normal spreading loads and radial compressive loads on the flanges/core respectively, be calculated?
RE: analytical mechanics off coiled-tubing
michaelparsons
If you don't get a reply on this post you may want to try:
Forum469  Petroleum production engineering
Coil tubing is more of a petroleum thing.
Good Luck
