instrument panel plastic
Does anyone have the specifications for the clear plastic that covers the instrument panel for the speedometer, tachometer,and other gauges?
RE: instrument panel plastic
The other posibility is polycarbonate, sometimes known by the trade names of Lexan or Macrolon.
What specifications are you after, as I have fileing cabnets full of specs
pat
I am searching for a plastic that can withstand a temperature range of -30 C to +120, available in several different colors, lightwieght, durable, and translucent.
Thank you very much for your time!!
Jerry
PC has a natural colour which is fairly clear, so can be coulured or tinted to just about any colour.
PC has very good impact strength, so is considered "safe" in areas likely to impact the occupant.
PC is fairly good to UV, but I would think that it should be UV stabilised for a dashboard application.
PC has lousy scratch resistance, unless treated with a special (and expensive) scratch resistant finish.
PC is very sensitive to attack from a number of common solvents, especially aromatics and chlorinated types.
Acrylic will NOT withstand 120 deg C, and is considered brittle. It has excellent scratch resistance, clarity and UV resistance, and is much better to PC re common solvents, but still susceptible to some solvents.
The move to PC was driven by temperature and impact strength.
pat
