Converting 3D solids to polygons in AutoCAD 14
Can anyone tell me if you can convert 3D solids to polygons in AutoCAD 14? Is there a freeware, shareware, or lisp program that can do this?
I want to import an AutoCAD dxf file containing 3D solids into the freeware program "3d canvas" but the program requires that the dxf file contain only polygons. I have also had this problem with other softwares.
Possibly something that converts from a solid to a mesh would work.
Thanks for your help.
Sincerely,
John
Sincerely,
John
RE: Converting 3D solids to polygons in AutoCAD 14
[2.7.5] Creating meshes from 3DSOLIDs
With 3DSOUT and then 3DSIN
However, former invisible face edges are then visible.
Subject: [2.10] How to set objects to Zero Elevation? FLATTEN.LSP
AutoDESK provides a PROJECT.LSP with two commands (PROJECT1,
PROJECT2) to project entities to a plane. This may be used to project
entities to z=0.0 and will be better than other lisps like
FLATTEN which only set the z-coordinate of all entities to zero.
Pro's: Handles Blocks and Polylines in turned UCS.
Contra's: Does not handle TEXT, 3DSOLID's and entities with a width.
For 3DSOLID's you'll need Mechincal Desktop or create meshes from
solids (see [2.7.5]), otherwise use this:
(defun c:flatten ()
(command "_move" "_si" "_all" "_none" "0,0,1e99" ""
"_move" "_si" "_all" "_none" "0,0,-1e99" ""))
The FLATTEN suggestions are not on the right track for this particular question. If they're answering ANOTHER question I'm unaware of, like "How do I get all of the ends of my vectors to Z=0 on my World Coordinate System UCS, Flatten is definitely the right answer.
Anyone know how to specify a different UCS than WORLD for flatten?
Anyway, Good Luck.
C. Fee
