Where to find examples of 3d optimization problems?
Hello everyone,
Can any one please tell me where to find Example problems of 3d optimization problems in website. If any one tells me i will be very thankful to you.
I have to optimize a pump casing. There are many parts in a pump casing like cover casing, end cover,body etc., Actually main aim is to reduce weight of the casing. How to optimize the weight of the casing?
RE: Where to find examples of 3d optimization problems?
Manigreat,
The website
http://www.feaservices.com
has a large models archive with pictures of models. Many of these have been optimized. There is also a good optimization article on the same website at:
http://www.feaservices.com/optimization.htm
I created an FAQ on this also. You should check it out, it presents a method of preparation for optimization.
Good luck
