New to this forum Help with rendering Acad 2002
Sorry folks , I am new to this list , let me intoduce my self , My name is Stephen , I design bits for motorcyles in particular..Royal Enfields,
The problem I am having with Acad is that the background will not show through a hole in a rendered drawing ...It did then I possibly fiddled with something
I have installed acad 2002 and still the problem is there, for an example a 5mm thick spacer with a hole in the middle against a green background . I should seethe green through/ in the hole but all I get is a white circle....If I apply a material to it then it becomes ragged like shadow over a playing field....
If you rotate it the effect decreases, So I moved in the lights...to no avail,....even went as far as to buy the manual.....no luck
Any Ideas?? HELppppppp!!!
I have been saving the Bitmaps , and touching them up manually!!1
Thanks in advance
Stephen
Thanks in advance
Stephen
RE: New to this forum Help with rendering Acad 2002
I extuded both cirdles then subtracted the inner one...
thanks for that
There are a couple of methods to get rid of the circles. One is the FILTER command. Another would be, if the solids are on a different layer than the circles, to turn off the layer of the soldids then erase the circles. Or enter ERASE select a fence and cross the solid and the circles, then enter R to remove and remove the solid from the delection set.
Hope that helps.
"then enter R to remove and remove the solid from the Selection set."
please feel free if you have any more suggestions I am all ears,,
Stephen
I can Email a simple drg and if you can render the same drg then its my machine ....
I ts been me all a long..( I thought so but i didnt want to tell the computer that!!!)
Thank you once again Most helpful
From a happy little Stephen
