Mineral oil
Mineral oil
I am tring to find a good cheap supplier of mineral oil. I plan on using it in a immersion cooling style computer project. I have look at 3M's web site and called some of their distributors. While I have not been able to track down any mineal oil with them they do have fluorinert, unfortunaly the cost is rather prohibitive at $3,000 usd. If you are wondering I was looking at FC-77 if you care to glance at it. In my searches I have not been able to track down a mineral oil supplier. If any of you know where I can get this I would be greatly appreciate it.
As I understand it, grocery store bought mineral oil does not have a high enough dielectric strengh to use this in an immersion cooling type project.
Another thing about the FC-77 is that it will "eat" certain plastics. PCB? The tank portion of the case will be made out of lexan or plexiglass.
RE: Mineral oil
I would guess that any oil distributor company in your area can provide "transformer oil." If you can't find one local try transformer manufactures like GE, Southwest, Howard etc.
Good Luck
RE: Mineral oil
RE: Mineral oil
Available in barrel-to-railcar quantities—
http://www.shell-lubricants.com/Electrical/tests.html
http://www.chevrontexaco.com
http://www.mobil.com/USA-English/Lubes/Your_Industry/Power_Generation_Utilities_Collection.asp
http://www.intech-edm.com/pdf/SpksFl00.pdf
RE: Mineral oil
I am also involved in a project whereby some piece of electronics will be (hopefully) cooled by oil filling a pressure vessel that will be submerged in water. We're looking at DC200 silicon oil by Dow Corning, the 20 cs viscosity type. Shell Diala has also been used in these applications.
I haven't looked at costs yet, but you can get in touch with Dow Corning for price info.
Hope this helps
RE: Mineral oil
Another possibility is Baby Oil just like you find at the local drug store. The added fragence may get annoying. These are fine as long as you don't intend to go to high temperatures. We use it for in-house engineering test of sensors used in diesel - much safer from a flammibility standpoint.
If you are trying to over-clock a high speed processor, you also need to be aware that the presence of oil instead of air above any high-speed busses that are on the surface of your circuit board may have their impedance affected resulting in signal integrety problems.
RE: Mineral oil
RE: Mineral oil
Hopefully the CPU fan won't make too much foam. ;-)
RE: Mineral oil
Now add mushrooms, shallots, garlic cloves and toss with 4 tablespoons of balsamic…
RE: Mineral oil
Lol also at the receipe...the Mineral Oil says it's laxative, think I'll save the dressing for the In-Laws! ;)
So...you guys like? Like I said, not totally done yet...more coolness to come! ;)
RE: Mineral oil
Also, (more importantly), how the hell did you construct your case?
RE: Mineral oil
My point is that if the copper around the processor isn't getting too hot, I don't know if you will be able to "pull out" any signifigant amount of heat through the mineral oil. (Replacing a very poor thermal insulator, air, with a better one, mineral oil)
Are my assumptions / statements valid?
RE: Mineral oil
I'm just wondering how easy that is to do. I remember him having a problem of water condensation on the air conditioning unit, which freaked him out 'cause he didn't want to fry his board. So basically I'm wondering if there's a way to pump the oil out of the case, cool it significantly, and pump it back in, setting up a loop to get the oil really cold. This might make it loud, which would defeat the purpose of having a fanless, quiet machine, but at least you could overclock the hell out of a system.
-Nuri
RE: Mineral oil
Small aside — There may be an eventual degree of softening/swelling in oil-immersed PVC wire insulation.
RE: Mineral oil
This is an awsome project and something I have wanted to try myself for sometime. I just didn't think it could be done effectively without the FC-77, which I believe has a much thinner consistancy than mineral oil. Hey, maybe I can even put my TV in an aquarium now, plastic plants and fish of course.
Please be sure to keep us posted.....
Cheers,
Cannibal
RE: Mineral oil
See http://www17.tomshardware.com/search/search.html?category=all&words=water+cooler for a comprehensive review of competing methodologies.
RE: Mineral oil
RE: Mineral oil
RE: Mineral oil
RE: Mineral oil
I hope JavaMoose writes back soon. I really would like to know how he built his case.
RE: Mineral oil
we use Shell dila-ax in our hi Voltage (120KV@50ma)power supplies. These supplies use convental electronics parts and large power tubes. I have seen no problems with these circuits with this product. I recently purchased a 55gal drum from Pennisula Oil here in the Bay area (Ca) for $350.00 dilivered. It's harmless to humans and circuits. You will still have to get the heat out though. Most Xformers use the same oil and have either cooling fins or large surface areas to get the heat out to the air. This means you won't be able go cooler that Ambient outside temp without another form of cooling. The spelling may be a little off but you can search and find the data (MSDS) data sheet.
Good luck -elf
RE: Mineral oil
On Shell Diala-AX, see:
https://thegenesisnetwork.equilon.com/ge...
http://www.shell-lubricants.com/Electric...
RE: Mineral oil
Info:
Box is ~12 1/2" Wide x ~12 1/2" Deep x 8" Tall. Bottom is clear-blue, hence the color the oil seems to be. Oil is pure clear. I bought one bottle, tested it with Multimeter...didn't carry any current, so I was good to go.
Everything is glued together with a special plastics cement. Nasty smelling and has a "WARNING - This Product contains blah blah cancer blah blah". You put it on with a syringe and capillary action pulls it into the seams of the plastic to seal it. Two coats inside seam, two coats outside seam...not a leak anywhere.
Cement I used:
http://www.ipscorp.com/ind_html/indprdct...
I used the one made for Acrylics, along with a squeeze bottle w/ syringe top.
TIP: DON'T try to pour it into the tiny bottle, instead, fill it like a baster (ie Squeeze air out of bottle, then dip the
syringe in the can to fill). You REALLY don't want this sh*t on your Skin/Hands!
As foor cooling the Oil:
There will be two small powerful (quiet) fans on the sides, top near front of case. The will be pulling air IN. Then there will be a larger (80mm) slower fan on the back of the LID drawing air OUT. The cooling stacks are going to be in the front, just to the side of the "Light Bar".
With this fan setup, air will come IN > blow across stacks > Out Top
This keeps cool air coming in, and the hot rising air out...should be pretty efficent!
RE: Mineral oil
http://users.adelphia.net/~javamoose/Oil...
RE: Mineral oil
RE: Mineral oil
I was in a store the other day and ran across a picknick 12v automobile cooler/heater box. I think it used peltier devices (cooling/heating Diode stacks). It wasn't very expensive <$30.00. This would make a interesting container for your Motherboard or you could just use the cooling system from it. I Don't know know if it would handle the heat load (you would probably have to add cooling fans for the hot side) but it would be fun to try And it could keep your Beer cold.
-elf
