Reducing Flange Dimensions
Is there a good website out there with a table of available reducing flange combinations, and standard dimensions?
Is a 12" x 6" ANSI 150# RF Weldneck reducing flange available?
Thanks!
RE: Reducing Flange Dimensions
ASME B16.5 doesnt mention WELDNECK reducing flanges, only THREADED and SLIP-ON (see page 69). From this my assumption is that the standard intimates that WELDNECK reducing flanges are not covered by the standard. No reason why you couldnt use a flanged reducer though.
PrudhoeBayAK:
Could you use a reducer and a weld neck or a reducer and a slip-on?
If you need to reduce down in the thickness of a flange, you will either have to use a PTFE reducing flange (might be unacceptable in some situations) or you could use a blind flange and drill it to suit inserting a 6" pipe into it (not normally used in the horizontal because of creating a dead-leg, normally only used in the vertical when there are space restraints and standard reducers are too large)
If you've got the space, I'd use a butt-weld reducer, eccentric or concentric, depending on flow direction, with weld neck flanges welded on.  Remember that a sudden change in piping diameter can have a significant impact on hydraulics.  As a rule, I wouldn't use a reducing flange on anything larger than 1-1/2" on the reduced end.
Also be very careful if you're going to try drilling a blind like paddymac suggested, if this is going into code pressure piping.  It is permissable by code, however only certain combinations are possible with a standard blind.  If memory serves, the largest reduction you can make by drilling a NPS 12 blind flange is NPS 4.  Larger than that, you have to use a hub blind to ensure there's enough material left on the blind to meet the pressure rating.
Note, this is a code issue, addressed in ANSI B16.5, which you should confirm what you're doing with - they've actually got a nice little table setting out the available reductions, but you have to start with a proper (normal or hub, depending on reduction) blind.  You drill a hole in a blind flange that doesn't meet that code, and without calculations to back it you could be on your way to court.
