EFFICIENCY FOR PENSTOCKS WELDED JOINTS
Hi everybody!
Would you help me define the efficiency to be applied when calculating wall thicknesses for a 1800mm dia penstock?
Which codes govern this kind of construction? Is E according to RT examination and weld detail as in ASME?
thanks a lot.
Heyner
thanks a lot.
Heyner
RE: EFFICIENCY FOR PENSTOCKS WELDED JOINTS
joints w/ or w.o./ reinforcements and if joints were examined by X-ray and other methods.
ASME codes will base their efficiencies on the ANSI piping and AWS codes. Structural engineers will primarily use AWS code.
Joint efficiencies have pretty much beem standardized and will be as high as 100% for full penetration welds w.o. reinforcement to 75% for joints that did not under N.D. examinations.
Hope this helps..
