domestic plumbing
domestic plumbing
domestic plumbing
Ever come across this problem?
If a wc is flushed, the water level in the adjacent wc bowl rises slightly - sometimes bringing with it foul matter?
RE: domestic plumbing
The closet that backs up is lower than the fist, and waste is relieved at second fixture. Check for blockage and pitch after lower fixture.
I would guess the venting system is either too small or blocked. Air pressure in the system is increased by simple displacement thereby moving the liquid in the adjacent bowl.
