Practices for Dimensioning Complex Aesthetic Surfaces?
Does anyone have any information on good online references, standards, or books that describe how to properly dimension/specify complex surfaces for manufacturing?
Tolerances on the surfaces are important but I can't figure a way to convey the appropriate information?
Is the solid model complete with multiple toleranced profiles sufficient?
RE: Practices for Dimensioning Complex Aesthetic Surfaces?
sirmick,
   Check out ASME Y14.5M-1994.  It shows you how to apply dimensions and tolerances to curved surfaces.  It IS the standard.
   In SolidWorks, you would apply a bunch of points, make these coincident to the curved line, and apply dimensions to them.  Rather than trying to apply tolerances to your dimensions, you would apply a profile tolerance to the surface.
                     JHG
