AutoCAD 2002 Text Line Weight
Can someone tell me how I can adjust line weight on text and dimension text? The 'ddim' modify box does not have a field for adjusting this. I'd like to retain the text style I'm using, but it has too heavy of a line weight.
RE: AutoCAD 2002 Text Line Weight
change the wight in the *.ctb before you plot...
regards Lothar
Win NT4.0 (SP6),
ACAD 2000i (SP2), ADT 3.0 (SP3),
OCÈ 5200
also try format ->text style and check out default setting; Do the same in dim style under format. Also have text in one layer and assigned lineweight. You will probably not see any change on screen but when plotted text will have changed. All above assumed done in MS.
EXIT is right!
Check your CTB file attached to see what color is WHAT "weight" ...
Check the current color for the text ...
Check the attributes ... in terms of weight number ...
Then find a color that has a LOWER number ...
That should help to eliviate your "Too Heavy Weight Text Issue"
Later ...
Take care & have fun!
Kevin
"Hell, there are no rules here -- we're trying to accomplish something." - Thomas A. Edison
