Converting Visio to AutoCAD (DWG)
I am looking for a solution to convert Visio drawings to AutoCAD (DWG). Since Visio does not support line types and fonts for DWG export the built in function is not acceptable. Microsoft declares it as a feature.
RE: Converting Visio to AutoCAD (DWG)
Good Luck, as I often have a hard time with Viso -> Autocad more than the reverse.
Visio Technical - Working with AutoCAD files
http://www.coe.uncc.edu/mosaic/mosaic_help/pc_help/visiotech/autocad1.html
Opening Visio 2000 Drawings in Actrix 2000
http://www.design-drawing.com/actrix/vis2act.htm
Compatibility between AutoCAD and Visio Part One of Two
http://www.design-drawing.com/visio/AcadVsVisio.htm
Compatibility between AutoCAD and Visio, Part Two
http://www.design-drawing.com/visio/AcadVsVisio2.htm
Michael Leary
Fresno, California
