Pre I-DEAS 9 Universal export
Hi all,
is there a way (maybe a hidden command) to export universal files from I-DEAS 9 into the universal format of an earlier version (such as I-DEAS 8 universal format)?
Thanks in advance,
Daniel
Thanks in advance,
Daniel
RE: Pre I-DEAS 9 Universal export
would you be able to export it as an IGES file?
maybe that will work tho you will probably lose alot of info along the way.
Cheers,
Daniel
in nastran, abaqus or ansys or other FE format, and read back in in I-DEAS 8?
Maybe that would work for you.
AutomotiveDesigner
I have tried to find out more but without avail. The info I read was that we are supposedly able to get data structured with nodal coordinates and numbering, with element formed by the group of node numbers, which are also identified with "material" or "element type" numbering.
This should be the initial mesh data. As for the FE result, it could be possible if we know the FE data structure.
