Liquid CO2 Pumping @ 450 Bar (6500PSI)
I'm interested if anyone has had some experience with pumping liquid CO2 at 450 bar. Our application is to pump 15 litres/second of liquid CO2 at 450 bar on a continuous basis. There are plenty of piston pump manufacturers that make pumps for bottle filling, however when we mention continous duty (24/7) they decline to guarantee their pumps.
We have looked at compressors but the cost for small flowrate in not viable.
fert
P.S I am a new user of eng-tips, should this be posted on other forums ?
fert
RE: Liquid CO2 Pumping @ 450 Bar (6500PSI)
Try FLOWSERVE, Sulzer, Ebara and KSB. These companies all manufacture large boiler feed pumps (pressures in the range that you are considering). Your capacity may be too small for this high head.
Designed specifically for liquid CO2.
www.smithpumps.com
pennpoint
Tony Deprado <deprado@thartech.com>
Thar technologies Inc.
They are in bussiness of making such pumps.
B.K.Desai.
and inspection services and have not seen this use before. Reply to Ernie at CO2Central@aol.com
