nitrogen purge blk steel pipe S.M.A.W. welding
gov spec requiring nitrogen purge while weld is being performed.gov spec ref's to ASME B31.1 and B31.9. Weld procedure QW-482 smaw, joint design vee,backing none,base metal (QW-403) P-# 1,,GRP # 1,Spec SA 106 GR-B,base metal .0625 to .436 all dia with in T range,,filler metals QW404,spec. no. SFA 5.1, AWS E6010 uphill& spec no 5.5 AWS E7018 uphill etc..???Why would nitrogen purge be used for this procedure ? Cannot find "code" ref that supports the use of nitrogen purge for these circustances. Reply to....
billvidmar@cobbmechanical.com
RE: nitrogen purge blk steel pipe S.M.A.W. welding
presence as an example mothballing to avoid corrosion and
TIG welding to ovoid oxidation of the root pass.
2. Nitrogen Purging is not a welding parameter applicable to SMAW
or any other welding process that ulizes coated welding
consumables or flux. (As far as I am concerned) However,
I would agree that it does good.
3. Nitrogen Purging is required while welding any pipeline with
traces of hydrocarbons as a safety measure.
General:
If the weldment quality was of grave importance XX18 electrode should of been used exclusively.
Cheers,
Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
End of all knowledge is the attainment of immortality!
