bending moments in bearings
I am trying to work out how to calculate the bending moment in a linear bearing, and I can`t seem to find any formula or information on the topic. I would be most grateful if someone could help!!
RE: bending moments in bearings
We generally don't recommend using the rail itself as a structural memeber because of this. I have seen some applications that work ok with a free mounted rail - ussually it's small loading and short strokes.
There are some rails on the market that are specifically designed to be used as a structural member - the rail is shaped like an I-Beam.
