motor control
motor control
How to wire a drum switch to motor starter on 3 phase 10 horse motor for lathe?
RE: motor control
RE: motor control
------Michael
RE: motor control
RE: motor control
1. McIntyre R. L. Electric Motor Control Fundamentals, Third Edition, MgGraw-Hill Book Company, 1974
Reference 1 describes three-phase motors of squirrel-cage type reversers by drum controllers.
Also, it shows the single phase motor reversal switch using Double Pole Double Throw (DPDT) switch. The start winding is controlled by the DPDT where phase and line are connected to the center (off) terminals (two), the start coil is connected to one direction terminals (two), and two conductors from the start coil are crossing to the reverse rotation two terminals inside the DPDT. Simple precaution is that the motor shall come to the rest before switching in the reverse. Also, suggest to contact or search
http://www.thomasregister.com
