Figuring hole position tolerance on Keensert installation
Does anyone have information on the additional hole position tolerance associated with using a Keensert type thread insert?
In other words, if the machine shop can make the outer threaded hole with a position accuracy of .004 inch, what is the hole position tolerance of the inner thread after the insert is installed?
RE: Figuring hole position tolerance on Keensert installation
