Material for burner nozzle
I am seeking an alternate material for a coal burner nozzle used in a cement kiln. Currently 310 grade stainless steel is used. However due to the abrasive conditions the wear out is rapid. Iam thinking of substituting by a tool steel material. Any help or suggestion welcome.
RE: Material for burner nozzle
500 degrees F. I would suggest a bearing grade of Ryton, PEEK or Polyimide all have
tensile's of 15,000 to 35,000 psi.
You may check out <www.aptechno.com>
Good Luck
