how to provide gate signals to the required thyristor in a vtg reg ckt
My aim is to design a vtg reg ckt based on the up(8085).The ckt consists of a trasformer which is provided with tappings.At each tapping a thyristor is being provided which are at different vtg levels.Now when the o/p vtg is less than the reqd vtg, a prgm is written in such a way that the reqd thyristor is on.How do i proceed once we obtain o/p from the 8085up.
RE: how to provide gate signals to the required thyristor in a vtg reg ckt
What do you want to power with the regulated VTG? How much
is the line VTG & variation, load and its variation and
how much VTG variation can you tolerate?
<nbucska@pcperipherals.com>
Hi, this is not a good idea, transformers do not like asymetric current, and you have to be careful not to have more than 1 tap conducting at once or you end up with a shorted turn condition.
