PEEK Chemical Compatibility
I´ve searching through the net some web pages where there are lists about the chemical compatibility between PEEK (polyethilethilketone) and others chemicals. With phenol and derived compounds I´ve seen almost nothing. Does anyone know if PEEK is chemically compatible with phenol and derived compounds, bisphenolacetone, cresol, etc.?
Thanks.
Thanks.
RE: PEEK Chemical Compatibility
i found this site to be quite complete on that topic:
http://www.netmotion.com/htm_files/wh_properties.htm
hth, chris
