Odour Control with Activated Carbon
Does anyone have experience using activated carbon for sewer gas odour control. Using caustic impregnated carbon to remove sulphides has been successful (30ppm h2s to less than 0.05ppm)however breakthrough of very low level VOCs (PCE, TCE, toluene - @200ppb) is causing other odour problems - sickly sweet smell(it shouldn't, given its odour threshold, but it is!).
Is using two types of carbon, impreganted and non-impreganted going to help?
What other practical add-on solution have are available?
RE: Odour Control with Activated Carbon
I would suggest working the problem through the major carbon drum/bed supplies such as calgon, who will give you adsorption isotherms and make some suggestions.
How frequently are you breaking through? have you tried to line a couple drums in a row, so a breakthrough can be sensed but does not result in odors to atmosphere?
209larry
markbaty@euremica.com
Email me for more info.
Contact me per e-mail engineering@envirocontrol.com or per phone (713) 910 3773
FrancisM wrote " A simplest method is to prevent H2S formation by chemical addition to the collection system"
I'm interest in know which kind of chemical I must add.
It is a simple wet scrubbing system which not only ventilates the plant, but clears odours from the surrounding areas of the wet wells, macerators etc.
The only detectable smell outside of the plant is faint "swimming pool" like.
Please contact me if you want mor details.
Profaic
That slight swimming pool smell, in all probability, is CHLORINE GAS - being the usual resultant of the hyperchloride reaction. Not sure of the allowable discharge limits of chlorine, but do know that this is the reason for the requirement of secondary scrubbing.
Best regards
(if chlorinating cyanides, watch our for even more toxic intermediate products if pH control is off)
