New forum for "easy" control relays and Pico controllers
A new forum is online which deals with the control relay easy (from Moeller). Since the easy control relay and the Pico control relay are very similar, you can also post question about the Pico PLC from Allen-Bradley. The link to the forum is:
http://www.easy-forum.net/index_en.html
RE: New forum for "easy" control relays and Pico controllers
easy-forum.net writes that Moeller has introduced a new multi-function display with the power of an easy800. It sounds not too bad.
http://www.regulski.com/cgi-bin/en/yabb/YaBB.pl?board=mfd;action=display;num=1050683801
