Pin Connection Problems
I’m having problems making a simple pin connection with Wildfire Mechanism. I’m selecting the axis of a hole in a block (part of a larger assembly) and the axis of a hole in a small bar the axis of rotation and the face of the block and a face of the bar as the translation constraint. Preview shows the bar in the correct position, but the Placement Status window shows “Connection Definition Not Complete” and won’t close. Any ideas as to what I’m doing wrong? Thanks.
Don
BCF Technology
Mohawk Industries
RE: Pin Connection Problems
If you select a planar reference normal to axis on part and assembly, it should work.
Otherwise try using Slider Connection.
Michael
