ASTM A193 Grade B16 Torque/Lubrication Reference Chart for Various Siz
I work with a lot of B7 & B16 Studs and Bolts. I have the reference Chart on B7 which list bolt/stud size, nut size, minnimum Yeild Strenght PSI and various lubricants with torque reference based on the lubricant used. The charts I have are for 50% thru 70% Yields. I'm looking for the same in regarding B16 Material. If anyone could help me on this I would appreaciate.
RE: ASTM A193 Grade B16 Torque/Lubrication Reference Chart for Various Siz
Yield and Tensile are the same. B16 is only stronger at higher temperatures but this does not influence the bolting up condition.
