Detection OF DTMF signals
which is the most
appropriate way to detect the DTMF signals using a
modem ?
modem ?
RE: Detection OF DTMF signals
What you need is a purpose-made DTMF tone decoder chip. These are made by Motorola and others.
Good luck.
I want to dial a nr using DTMF, and the transmit data using DTMF to a unit that can decode it. Can I do it using the AT command set? What command do I use? Otherwise what will be the most appropriate way? I am doing all this from a C# app.
TTFN
Richard
