Rotating a Part
Rotating a Part
Rotating a Part
I am have the darnest time in rotating a part to the right axis in  SW. Example:  In Autocad I make the center section(HUB) then make a blade on  the outer perimeter .then I rotate the blade to the angle desired.being able to rotate the object in only the view chosen. In SW i can't control just one axis without affecting the other.
RE: Rotating a Part
I am not sure if you are talking about a Part model or an Assembly, but it shouldn't matter.
If you want to move a part in only one axis, select either a model edge or temporary axis with your mouse, while you have the Rotate tool active.
If you are talking about creating a Part model, and you want a feature to be at a specific angle, then you have to dimension the angle in the Sketch of your feature.
Ray Reynolds
Senior Designer
Read: FAQ731-376
"Probable impossibilities are to be preferred to improbable possibilities."
