Material equivalent
Material equivalent
Can someone out there tell me the DIN equivalent of Alloy 20 ( ASTM A744 CN7M )?
avinodkumar
avinodkumar
RE: Material equivalent
the only 700's I find for SAND cast alloys are
A713 & A771 which we pour both,
Bruv
Bruv
ASTM A 29 Standard Specification for Steel Bars, Carbon and Alloy, Hot-Wrought and Cold-Finished, General Requirements for lists the following grades that are close:
5115
C = 0.13-0.18
Si = 0.15-0.35
Mn = 0.70-0.90
Cr = 0.70-0.90
5120
C = 0.17-0.22
Si = 0.15-0.35
Mn = 0.70-0.90
Cr = 0.70-0.90
The DIN/EN grade 1.7139 has more Mn & Cr than either of these grades, so its hardenability will be higher than 5115. 5120 has slightly more carbon so it will be closer in hardenability, even with reduced Cr & Mn. Depending on your application, one of these grades or another alloy steel may be suitable.
Regarding equivalent steels & conversion among national & international standards, the following references are the best:
Worldwide Guide to Equivalent Irons and Steels, 4th Edition
http://www.asminternational.org/Template.cfm?Section=BrowsebyTopic&template=Ecommerce/ProductDisplay.cfm&ProductID=11476
Stahlschlüssel, 19th Edition
http://www.asminternational.org/Template.cfm?Section=BrowsebyTopic&template=Ecommerce/ProductDisplay.cfm&ProductID=11723
