Joining gears in SW2000, how to?
How to join two or more gears (pinions) in SW2000, and make them work?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Joining gears in SW2000, how to?
Ray Reynolds
Senior Designer
Read: FAQ731-376
"Probable impossibilities are to be preferred to improbable possibilities."
YOu do not have that functionality in 2000. 2001+ has physical dynamics but I would attempt to do a simulation like that with it... its very math intensive and would bog most processors and not show much at all for you. Better way would be to use Cosmos Motion, and use your assembly file, define a rotary motion on one gear, and create a coupler between the two that says for every degree of rotation on gear1, rotate gear2 by so many degrees (based on the gear ratio).
Wish I had better news for you...
Jon
jgbena@yahoo.com
