Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks a lot Mate! I can't tell you how many times your site has saved my "rear". hehe..."
Geography
Why use tens of GHz to communicate between satelites and ground base?
Satellites (Electrical)
19 Feb 01 8:42
If you could help me with that problem.
omargtg (Computer)
29 Apr 01 21:25
Early Satellite communications use frequencies below to 1 MHZ due to the state of art of technology. However, with the advance of new technologies, it was possible to use higher bands. The use of ten of MHZ is due to the next considerations:
- Today communications are hungry of higher bandwidths, so the use of higher bands of frequencies.
- The higher frecuencies the lower power to reach the satellite.
- The lower power the smaller satellite dish antenna you will use, so the cost is lower.
- But, the higher frequencies, the higher attenuation due to the space free losses. However, the power is still lower compared with lower frequencies.
   These are some considerations in this field, if you need further information contact me to omargtg@yahoo.com and I'll give you public literature where you will get more informated.
          Omar Torres
etpineda (Electrical)
12 Jan 02 0:30
Other reason is the size of wavelength with respect to frequency.
Wavelength is inversely proportional to frequency, therefore low frequency possess longer wavelengths than high frequencies.
What is the significance of this?
Between satellite and earth station, we have this ionosphere. Frequencies from VLF to HF are affected by this ionosphere. The layers of the ionosphere refract these frequencies back to earth. Frequencies in the bands of VHF, uhf and higher bands tends to pass thru' the ionosphere, therefore it can scape to the space to reach the satellite in its orbit.
The ionosphere is affected by the solar activity of the sun. The displacement of one ion to the other in the ionosphere is enough for wavelength of the VHF and higher frequencies to pass thru, unlike the wavelengths of HF down to VLF.
Close Box
Join Eng-Tips® Today!
Join Us             Close
