Multiframe4D
Multiframe4D
Multiframe4D
I discovered that we can draw the entire structure, 2D or 3D in AutoCAD14, explode all polylines, position the UCS icon on TOP view and export as DXF file.
Import in Multiframe in the same units you've drawn and you can save time in modelling in MF graphical interface. I found it's more productive because most files comes in DWG or DXF format.
MP
RE: Multiframe4D
I have just play with Multiframe 4D for about 15 hours today, doing pushover analysis of a simple 4-bays portal frames.
Multiframe is NICE!
DP
