How do I calculate impeller size?
Currently I have a pump with an 11" impeller at a discharge pres of 22psi and 112GPM.
I'd like to know how much will the flow and/or pressure will change if I trim or increase my impeller size.
is there a formula for this ?
thank u
RE: How do I calculate impeller size?
Flow may not change. Pressure will be proportional to diameter squared.
shup0739
For general terms the pump affinity laws apply to impeller size or rotating speed.
FYI:
22 PSI at 112 GPM sounds low for an 11 inch impeller.  Hope this is a slow running pump.
shup0739,
As suggested by D23 use the affinity laws to provide a rough appoximation of the effect of changing impeller size.
Q1/Q2=D1/D2
Hd1/Hd2=(D1/D2)squared
HP1/HP2=(D1/D2)cubed.
You can expect this formula to give you accuracy within 10 to 30%.
Affinity laws are the best equations to calculate and estimte the changes, however these are constant efficiency equations. But when there is a change in impellar size, efficiency does change and hence these equations may not predict the changes very accurately, however they definitely give a close estimate.
hope this helps.
