Stiffened flange for penstock
Hi everybody:
I'm about to check calculations for a 1800mm diameter penstock flange (to be connected to a butterfly valve). I'm using ASME VIII Div 1, like a loose flange. It gives me a 135mm thick ring plate.
Let's say we want to reduce that thickness to 70 mm helping it by using stiffeners. I know it can be done, of course not covered by ASME code. The problem is I don't know how to perform these calculations taking into account those stiffening considerations... we did a preliminary check considering the ring plate portion between two stiffeners as a simple beam, it gives something near 45mm.
OK, what I'd like is to find some way to say:
"The proposed stiffeners are equivalent to a thickness of 65mm, so 65 + 70 (plate thk) give us 135" and after that use that input to check it according ASME.
May you help me???
Thanks in advance.
Heyner.
May you help me???
Thanks in advance.
Heyner.
