Subsea Tie-in
Subsea Tie-in
Dear all
In order to make a tie-in to the exising subsea pipeline, it seems for me the best way is to employ the hot-tapping in case the system shutdowm is not permitted. But if it is permitted for a certain period, does anyone has any idea what method should be applied in term of engineering, cost effectiveness and also for future matainence accessibility. Your help will be very appreciated.
Thank You Very Much
Thank You Very Much
RE: Subsea Tie-in
RE: Subsea Tie-in
Narendranath R
Pipeline engineering is made easy with state of the art computer software, visit www.narendranath.itgo.com.
RE: Subsea Tie-in
Contact IPSCO (UK) ltd., www.hottaps.com
If you provide me an email address, I can give you the contact number and email address of someone I know in IPSCO, who could give you all info required (technical, price...).
cedric
RE: Subsea Tie-in
We have replaced a portion of subsea pipeline (10") using mechanical connectors. We completed the hole operation with a help supply vessel and divers.
RE: Subsea Tie-in
General Approach
M.Munari
Engineering
Central Sumatra Gas Project
PT Perusahaan Gas Negara (Persero)
Bla-Bla-Bla
This paper is to describe the pipeline shifting where shifting the existing laid not exactly route per design on the seabed or trenching. The case exists due to some factors such:
1. Receiving GPS (Geographic Positioning Station) on the barge is poor.
2. Design route not same with trenching design.
3. No fairly coordination on the site
4. Not proper trenching (above, bottom, width)
5. Barge works under extreme conditions
Purpose
This paper is describing a situation of shifting pipeline procedure without cutting off at end the pipeline.
The pipeline that lay on wrong route shall lift 4 meter of the touchdown and shall shift 4 meter maximum of initial point.
Potential Factors
The below are list of some potential factors to be considered:
• Easy to be done
• Lifetime of working is short
• Risk to damage
• Constraints not free (fixed)
• Stress at each ends increase
• Tend to create the torque
• More cheaply cost than other methods
• Un-conventional Method
• Highly Percentage system mode of failure (SMOF)
Disadvantages
• No Recommend Standardizations
• No assurance
• Risk to damage
Advantages
• Easy to be done
• More cheaply cost than others
Design Basis
The pipeline installed with refers to DnV 2000 Standardization (OF-S101).
A. Designed Pipeline Data
Outside Diameter (OD) : 0.7112 meter
Thickness (t) : 0.0127 meter
Inside Diameter (ID) : 0.6858 meter
Grade : API 5L X 65
Density (s) : 7850 Kg/m3
Yield Strength (S) : 65000 Psi (448 N/mm2)
Tensile Strength (T) : 77042.41 Psi (531 N/mm2)
S/T Ratio : 0.84
Modulus of Elasticity (E) : 1.94 x 105 N/mm2
: 29000000 Psi
Linear Coefficient Tensile Strength (t) : 2.97 x 10-4 mm/mmoC
Procedure Working
Step by Step
• Set up barge on location
• Diver inspection (to observe backfill materials on the shifting location, pipe position in relation to trenching)
• Inserting sling around pipe at lifting points (4 points with interval 20 meters) with diver, if necessary using air jet compressor.
• Lowering wire from davits to joint onto sling
• Lifting pipe to y-axis direction with 4 davits (refer to Lifting Schedule) up to max. 4 meter (interval lifting 0.5 meter)
• Shifting pipe to x-axis direction with no lifting (interval 1 meter, max distance 4 meters). Barge shall move by foot-print of anchoring system.
• Lowering pipe y-axis direction with 4 davits (refer to Lifting Schedule) up to max. 4 meter (interval lowering 0.5 meter) on to trenching.
• Post-shifting survey to make sure that pipeline already on right position.
• Report
RE: Subsea Tie-in
RE: Subsea Tie-in
Field Engineer,
TL Offshore Sdn. Bhd,
Malaysia.
