316SS minimum yield
316SS minimum yield
What is the industry standard typical minimum yield strength (if there is such a thing) on 316SS bar stock?
The only spec I can find is ASTM A 479 which lists 30ksi in the annealed condition and 65ksi in the strain-hardened condition.
Is there any other commonly available condition resutling in a minimum yield between 30ksi and 65 ksi?
RE: 316SS minimum yield
Annealed == dead soft
1/4 hard
1/2 hard
3/4 hard
Full hard == fully work hardened.
316 can be ordered in most of these conditions.
Nick
go to: www.matweb.com
Search for 316ss or 316L or t-300 series stainless.
the best data looks like its from Carpenter adn on their BIO-DUR (registered) alloy, wich is especially clean for ultimate corrosion resistance....
You should be able to get the supplie (vendor) to provide A2LA accredited tensile test results of anything you want to buy....
mcguire should be along in a bit and have some more info....
Nick
