Selection of a structural engineering software
I am a freelance strutural engineer, i am presently doing alot of analysis for wind and earthquake loadings of reinforced concrete building structures( not usually greater the 4 storeys), retaining walls, and also timber roofs of houses to B.S Codes. This analysis is very repetitive.
Can anyone recommend a reasonably priced structural engineering software or that would meet my needs?
Best regards
D.W
Best regards
D.W
RE: Selection of a structural engineering software
But I think that Multiframe4D, SectionMaker and SteelDesigner will help you a lot and it's probably the best price of the analysis software.
Best Regards,
The program is capable of linear and non-linear analysis and permits the user to write sub-routines for automatic load generation.
With respect to structure modelling, I've found that it is faster to use a 2D or 3D CADD program to generate the basic frame geometry; convert the CADD drawing to dxf file format; then import the dxf file into Multiframe. Very fast method for generating frames that are not orthogonal with respect to any 3D coordinate system.
It includes steel design modules for US, British, and Australian standards. It also includes a section builder which will permit you to model wood or concrete beam, column, and shear wall elements.
Multiframe costs less than US$3000 and its annual subscription rate runs about $300 which entitles you to product support and free program updates.
Best of luck to you.
