Dock locks/truck restraints
I am working on a warehouse improvement project and one of the major jobs is to install some dock locks/truck restraints. There are so many designs to choose from. Does anyone have any experience installing dock locks or know of the best designs/suppliers. I would like a dock lock that has a good vertical range. My preference so far is to the hook versions.
Che51
Che51
RE: Dock locks/truck restraints
I can visualize an array of actuated plates on the pavement near the dock. After the truck is backed all the way to the dock, the plates swing up with air pressure. The pivot is on the dock side. If a plate is under a set of wheels, it does not project up. This is what sets the actuation pressure. There is a fine balance between sufficient resistance to collapse under truck weight and the ability to resist collapse under the force of a truck trying to roll.
Rite-Hite APB-1000 Series automatic push button levelers.
Rite-Hite VBR-400 Series vehicle restraint.
Frommelt Insulator dock sealing system.
TKO welterweight dock doors.
As I said everyone is pleased with this setup, and that is saying something! Our Dist. group is very hard to please.
If you are near Illinois I can give you contact info.
