Polar Moment on Inertia "J"
Im not sure if this is a trick question, but i have gotten more than one answer.
What is the equation of Polar Moment of Inertia of a uniform beam supported at one end with a length of 2L?
So far I have gotten...
mL^2 and 4/3ml^2 The first answer treats the problem as a pendulum with a lumped mass. The second uses the equation 1/3ml^2 and sets l=2L. Which is right?
RE: Polar Moment on Inertia "J"
Depends on how you are rotating the object. I would use
J = m * 22* L2 /3
But this is valid if your uniform beam is a thin rod
J = m * 22* L2 /12
or J = m * L2 /3
 is valid when the center of rotation is in the middle of the beam
regards
Steven van Els
SAvanEls@cq-link.sr
Yep, first identify how the moments are going to happen or happening, if any, then determine the right equation from there!
lets face it, there's a Polar Moment for just about anything right? it's in the books and the items are not moving in them, so first determine or even "hey, is this thing subjected to a moment"? because if not, then your answer will be wrong.
you said:
"What is the equation of Polar Moment of Inertia of a uniform beam supported at one end with a length of 2L?"
is this a uniform beam or uniformly loaded? is it light loaded, intermediate loaded, is it center loaded, etc.?
you also said: (supported at one end), shouldn't you be taking it to be a cantilevered beam? M1= -wl^2/2 M = w/2(l-x)^2 ?
Joseph Moylan
moygr1@home.com
