YS and UTS for A516 Gr 70 Material for temp up to 1400 degF
Will appreciate if you material expects can advise where I can find the yield and ultimate tensile strengths of steel material like A516 Gr 70 for temperature ranges from 600 deg F to 1400 deg F.
Thanks in advance
Thanks in advance
RE: YS and UTS for A516 Gr 70 Material for temp up to 1400 degF
Thanks for your response.
There is no specific application. I just want to prove to myself that the API RP 521 suggested the blowdown duration of 15 min when a pressure vessel is under a fire is too long. I suspect the vessel will bleve before it is blown down to atm pressure.
Hope to hear from you again.
