Parallel conductors DC system
I need to feed a DC motor armature with about 1650 amps.I plan on using (5) 500MCM conductors per pole. Can I run (2)pos conductors and (2) neg conductors plus ground in two conduits and (1) pos conductor and (1) neg conductor plus ground in a third conduit?
RE: Parallel conductors DC system
Conduit # 1: +500MCM x 2 -500MCM x 2 and Ground
Conduit # 2: +500MCM x 2 -500MCM x 2 and Ground
Conduit # 3: +500MCM x 1 -500MCM x 1 and Ground
Grounding conductor must be the same size in all conduits.
250MCM for 2000 amp overcurrent devise.
Per NEC Article 310.4 Parallel conductors.
Per NEC Article 310.15 Ampacities.
Try 2-4" with 6-500MCM and 1-250MCM Grounding
