Material Properties for A 611
Can anyone help me I need the material Properties for this material Youngs Modulous
         Possions Ratio
         Mass Density
          Thermal Coefficient
RE: Material Properties for A 611
Young's Modulus for steel is mostly invariant to chemical composition, processing, etc.  The value is around 207 GPa.  Poisson's ratio is usually accepted to be 0.29.  Mass density is ~ 7.85 g/cm3.  Thermal expansion coefficient is ~ 12 x 10-6m/mK from 20-100 C.  From 20-200 it is ~ 12.5, 20-300 it is ~ 13.0, and 20-400 it is ~ 13.6.
I assume you are referring to ASTM A 611.  If so, you can use the properties of SAE 1020:
Young's modulus E = 205 GPa
Poisson's ratio ν = 0.29
Mass density ρ = 7.87 · 103 kg m-3
I assume your "Thermal Coefficient" is the Linear Thermal Expansion Coefficient.  If so, then use α = 11.7 · 10-6 K-1
If you are looking for these properties vs. temperature
have a look at http://www.jmatpro.co.uk.
