Inrush 480-240/120V 50kVA Xfmr
Considering FLA for the primary of the 480-240/120V 50kVA single phase transformer is 104A; and the secondary load is fixed and relatively low; how tight (low) can I set the primary thermal magnetic circuit breaker without false trips of the primary breaker due to the inrush current? 80%, 90%, 100% or ????? of FLA.
RE: Inrush 480-240/120V 50kVA Xfmr
Based on NEC article 450, 125-250% is specified. What is the purpose for anything lower? In any case, three-wire secondaries must have their own overcurrent protection—primary alone won’t do it per NEC.
The secondary circuit breaker will be 200A.
The contractor is attempting to save his money by re-using an existing panelboard which will not accept a breaker bigger than 100A. I am trying to establish a code violation to force a new panel be installed with a 125-150A primary breaker to avoice nuisance trips of the main.
Thread238-10885
Thread238-35609
Good luck
Occasionally there is no good substitute for well-composed/unambiguous contract verbiage.
A typical 100A molded case C/B is so rated because it has a thermal overload trip of 100A. This means that eventually, the C/B will trip for current over 100A. Believe it or not, it can take well over 2 minutes for most 100A C/Bs to trip at a 300% overload(300A). This C/B also has a magnetic short-circuit trip function(usually non-adjustable for this size C/B) which will trip with no intended time delay at current values approximately 10x the current rating.
A 50kVA transformer may have an inrush current of between 8 and 10 times its FLA, for a maximum time of 0.1s. This may cause the nuisance trips you are concerned about. A quick look at the time-current curve of the C/B plotted against the inrush point of the transformer(a coordination graph) will indicate if there is a possibility of interference.
What is the manufacturer and model of the C/B?
I will try tomorrow with my ETAP program and check for you.
Is the C/B a C-H or ITE? I believe they both have a model EHD. Some C-H devices used to be Westinghouse, and some ITE devices are now Siemens, but I've never heard of both C-H and ITE together on one C/B.
The SKM damage curve is adjustale, and is currently set at 12x for .1 seconds and indicates approx 720A (obviously not 104A x 12) on the TCC drawing. I though maybe the 12x was something other than FLA, but I believe that ANSI indicates 12x the FLA, so it should be 1248A instead.
Since it is such a small transformer, the manufacturer will not indicate the design parameters, and it is not worth testing prior to installation.
Sometimes the obvious is so not-obvious for me. Thanks for the idea, I think your right.
http://www.siemens.com
http://www.siemens.de
http://www.ad.siemens.de/cd/energie/index_76.htm
http://www.ad.siemens.de/cd/energie/html_76/leistung_3vf.htm
http://www.ad.siemens.de/cd/energie/html_76/products.htm
etc. for more info
