Problem Installing SW 2001 + and SW 2003 using Win 98 SE
I get the following message when trying to install (running the install.exe file) SW 2001 plus:
"The current platform - Windows ME/98/95 (i386)- is not supported by the following SolidWorks 2001plus distribution:
C:/My Documents/SolidWorks 2001 Plus/
Please obtain an appropriate distribution, then retry installing."
I thought SW was Win 98 compatible? How do I fix this problem? Thank you.
RE: Problem Installing SW 2001 + and SW 2003 using Win 98 SE
Crashj 'it is called "Progress"' Johnson
You really don't want to run that on that OS do you?
Supported OS for SW03:
Win98 Second Edition - BAD Memory Managers
Win ME - BAD Memory Managers
XP Pro - SP 0 or 1
Win2000 - SP2 or 3
Win NT 4.0 - SP6
See the orange sheet that is sent with your SW CD's for more information.
I hope that helps,
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.3dmca.com
FAQ731-376
When in doubt, always check the help
