GE Genius Handheld Terminal for the I/O Modules
In addition to field calibration equipment during instrument loop testing we are using a laptop PC, a Wonderware workstation and a handheld terminal for the GE Genius IO. It appears that we need an additional handheld terminal for the Genius. Is there another way to set ranges etc. on GE Genius than the handheld terminal that plugs into the module?
John
John
RE: GE Genius Handheld Terminal for the I/O Modules
I have never done this as it seems a lot of trouble to go through (setting up the COMREQ) when it is so easy (and straightforward) to configure the blocks using the HHM. The fact that you can copy the configuration from one block to another of the same type is of course a big timesaver. Of course the blocks have to be connected on the same bus to do that.
If you want to pursue remote configuration, it is detailed in Chapter 5 of the Series 90-70 PLC Genius Bus Controller User's Manual, GE Fanuc publication GFK-03398.
Good luck!
