Cascade input latches
Hi everyone,
I am looking for a parallel in, serial out latch to provide more inputs for the microcontroller. The one I found is the 74HC165. Do you know if it is possible to cascade few 74HC165s together? I can't find this information on the datasheet.
Thank you for your help!
Thomas
Thomas
RE: Cascade input latches
Regarding your initial statement that you want provide "more inputs to the microcontroller", is it really SERIAL inputs that you want? Don't you want to make a multiplexer system for lots of parallel inputs?
http://www.e-insite.net/ednmag/archives/1996/041196/08di1.htm
etc. for more info
