Pro Sheet Metal, Setup Parameters?
When you hit Setup Parameters and you get the box with all the stuff in it, what is this for? I see it lists all the feature I put in and there attributes as we'll as the the Y factor and all that, looks like everything that defines my part but why?
RE: Pro Sheet Metal, Setup Parameters?
Anybody will be able to find and see this useful information either on the 3D model, or on the drawing. For example when you request a quotation, or order tooling from a vendor, they will be able to find all the information they need on the model.
It’s a very good practice to add as much information as you can on your Pro/E model.
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
