Fuel Ethanol Plant Design References
Hello.
There is a resurgence in fuel-ethanol from corn or grain, with numerous new plants being built through-out North America (typical size of 40 million gallons per year, $50 MM). The designs have changed drastically over the last 10-20 years, and the plants are now very tightly heat integrated and energy efficient. Am having a tough time finding up-to-date references for yse in design and plant assessment work.
Can anyone recommend references or handbooks on modern fuel ethanol plant design?
Thank you!
Thank you!
RE: Fuel Ethanol Plant Design References
The consumption is around 0,25 kg Steam per kg Dry ethanol.
