lost hatch pattern
lost hatch pattern
Has anyone run into this problem with CATIA V5? I created a section view then went to modify the hatch pattern (properies) by selecting 'none' in the "Pattern table". Once this is done, the Pattern feature is no longer selectable in the properties dialog box, so in essence you can't retrieve or add any hatch pattern to this previously generated section view. Also, the hatch pattern was dropped off all of the other section views and any future section view from any projected "front view".
Is this a bug? Does someone know the trick to retrieve or generate a new hatch pattern?
jharoldson
jharoldson
RE: lost hatch pattern
I ' ve just try your problem... you can find hatching back by setting a material on you part..
This will give you hatching in all section - section cut in your catdrawing. you can after that delete your material, the hatching will stay.
have fun
Eric N.
catiav5@softhome.net
