disassembly of a helicopter
i like to know what is the best mathematical approach to maximize my out-put in disassembly of an aircraft. I have standard times and presedence chart.
Any help is appreciated
mmokri
mmokri
RE: disassembly of a helicopter
A spreadhseet that has "precident" and "subject" task indications can be set up to narrow the possibilities down. A "brute force" approach, by hand or using macros, can then be applied to find the minimum time. You may find that starting at the end and working forward will enable you to quickly identify the critical path...
MikeVV
