French Material Spec 35NCD16
Does anyone know a USA supplier for this material? If not,
An overseas supplier would be helpful. 200mm. Diameter
x Approximatley 600mm length bar is needed.
RE: French Material Spec 35NCD16
Are you sure you do not need E35NCD16 ? (the E indicates consumable electrode remelt, and is usually required for this steel). Do not know of any suppliers in USA, Aubert & Duval (Aubertduval.fr) are the main French specialists for this grade.
http://www.timken.com/products/specialtysteel/engineering/tech_info/PDF_Files/Lescalloy_35NCD16_VAC-ARC.pdf
In Europe, there are a number of producers of this grade, including Corus, Ascometal, Krupp, Saarstahl, and Sidenor. I believe that Corus is the only one of the above named mills that produces this grade by a consumable electrode method-- VAR, similar to Timken Latrobe. Allvac, Electralloy, and Carpenter all have remelting capabilities, but none of them list this as a standard grade.
If you require only a small amount, then you should be able to obtain it from Timken Latrobe's steel distribution site:
http://www.timken.com/products/specialtysteel/facilities/steeldistribution.asp
